Have had an issue with my turbo 4cyl for a while now. On each 1/4 mile pass it will puke about a 1/2 qt of oil into my catch can. I have checked everything I know to and am stumped.
Combo is a 2.9L with a BW 69/75 turbo. JE pistons, Crower rods, etc. Running 35psi it runs 9.60-9.70 at 140 in my 3250lb T-bird
I bought this as an unassembled setup and the parts were new with an unknown ring set. I set the ring gap at .026 on top and .028 on second with a standard tension oil ring.
It had the oil puking issue with it so after a few months I pulled the engine and replaced the rings with new TS AP stainless rings, set them at the same gap with a fresh hone and it didn't change a thing. Still pukes the same amount of oil as before.
The car runs good and doing short but high boost street blasts puts nothing in my catch can but a full 1/4 mile run does it every time.
I run a -12 hose from the block and another -12 hose from the VC to a large vented catch tank. Block and VC fittings have a baffle plate below them so no direct path for the oil. No dips in the hoses to trap oil and make a blockage. No crank scraper or windage tray in the bottom end.
I have tried running it a quart low and made no difference.
I did a leakdown test and came up with the following:
#1 9%
#2 11%
#3 12%
#4 11%
Not spectacular but not bad enough to cause this, right?
I have looked at vacuum pump and dry sump setups but that seems like overkill. Any tips/tricks/ideas?
#1 9%
#2 11%
#3 12%
#4 11%
