Evolution of the Species
Drag racers, like any organism, will adapt to their environment. I was reading the guest column on dragracingonline by Steve Earwood, operator of Rockingham Dragway, (http://dragracingonline.com/columns/guest/xiii_10-1.html) about the rapidly escalating price of traction compound. He points out that the cost of the compound has doubled in the last couple of years, and as a track operator, he would be forced to either lighten up on the track prep, or charge more for race entries.
This got me to thinking about the way things used to be. Now it seems to me there is a lot of criticism directed toward racers who are using 14” wide tires on 10 and even 11 second cars. “if you can’t make it work on a 10 inch wide tire, you lack talent,” seems to be the attitude.
Back in the late 70s and early eighties, most racers, myself included, going eleven seconds or better were running “steamroller” tires. Some of ‘em hung out of the fenders, while some of us had ‘em tucked neatly inside the fenders. Ours were 14.5X32 on a mid ten second car, and the same when it went as fast as mid nines. This probably had more to do with the track prep of the day than a racers lack of talent. I can remember the traction compound in use at our local track was 7-Up syrup. And even then, probably only for the first couple hundred feet at most. The mantra then was “There’s no such thing as too big a tire on a bracket car.” (Keep in mind that 9.90 index racing was in it’s infancy at that time, and it was the closest the sportsman racer could come to heads up racing).
So, I have to ask. Would the racers currently espousing the superiority of their small tires still be of that opinion when the track operator is forced to cut costs by not doing as much prep as is common these days?
Would these same racers fall victim to a racer with steamroller tires because the small tire guy couldn’t hook up?
Are the Drag Radial guys going to even be able to get down the track?
What’s going to happen when track operators cut back on the stick-um?
Will we see an evolution back to big tires?
Thoughts?
Thoughts?
