Just wondering if guys who switched from a et street to a drag radial had to do alot of chassis tuning like changing shock settings,caltrac adjustments etc or were you settings pretty good with the tire change?
I went from a Bias Ply slick to a Radial Slick and picked up a thenth in the 60'. I run the ranchos on 6 or 7 with a little preload on the bars, and in the front I have my QA1's 1 click from being all the way tight for extension... Hope this helps...
Went from dead hooked with an ET Street to 60 foots all over the place with the M/T Drag Radial. So far, it dead hooked ONCE. Every other pass I got to pedal it. I have since changed springs and shocks all the way around and will try again. I WILL get the radial to work. THIS IS ON AN UNPREPPED TRACK. I am sure the radial would work on a regular race night and not on T&T.
I noticed that when I first put my radials on, my sixtys were all over the place until after about 15 passes. Kinda like a break in period, but after that period my 60' are deadly pass after pass...
