1 - 5 of 5 Posts
I ran a et street radial and i ran a 275/60/15 now i have et drags which are 26/10.0/15. Now im wanting to go ET street what size do you think i should run with a 15in. wheel, 3.73 gears, 2900 pound, 425 hp fox body.
pretty sure the 26x10x15 et drag is the same size as a 26x11.5x15 et street.
Drag is measured at the tread and the street is at the sidewall.
If you want an ET Street that is the same size as your slick, go with the 26X11.50-15LT, part # 3753.
If you want a size similiar to your P275/60R15, you'll want the 28X11.50-15LT, part # 3754.
Thanks,
Jason Moulton
1 - 5 of 5 Posts
