1 - 19 of 19 Posts
I am running a FAST XFI with Cherry Hall Effect Sensors for Cam and Crank. They are the red 12mm ones.
While my car is running at a consistent RPM I will get a false reading. At idle the reading will jump about 3k RPM.
Do I need to install a pull up resistor or anything in the wiring?
I wired it into a 12v source. Should I rewire it into a regulated 5v source?
EFI/N2O JUNKIE
You need to check and see if they have a built-in pull-up or not. You also need to see if they can run on unfiltered and unregulated power. Normally they can, but check.
Most hall effect sensors pull the output low when a magnet is near, and either have an internal pull-up resistor or need an external one added.
the spec sheet I have on it does not say regulated or unregulated but it can run on 5v - 24v
It also shows the resistor added in line. It is a common sensor everyone here has recommended and I have ran them without any resistors before but for some reason this one is giving me issues
EFI/N2O JUNKIE
If they rate it from 5 to 24 volts, then it has a built-in regulator already. If you have a Radio Shack by you, you can probably get a 4.7K resistor to use as a pull-up. Wire it between the output of the sensor and the positive voltage coming in. See if this helps you.
Just a thought, some hall effects are clock sensitive. Meaning they have to be orientated correctly to the passing trigger. Any that I have worked around will have a flat spot on knurled area. Look at the spec sheet. Or a more basic problem could be its just fucked up. Do you have any more to try? Manufacturing errors do happen.
EFI/N2O JUNKIE
Ha, Oh so true! :)
One of the Hall Effects I use al the time at the shop only works with the magnet "polarity" correctly. IE: It only "sees" a North or a South pole passing. I always forget which one, but I know how to install it so the Hall Effect works correctly.
Discussion Starter · #9 ·
I have extras I can try. I will add the resistor first and see if that fixes the problem. Its not the easiest sensor to replace due to how my turbo kit is routed
...Cherry Hall Effect Sensors for Cam & Crank. They are the red 12mm ones.
What's the sensor air gap adjusted to?
If it runs OK and shows 3K or more wrong on the tach. Why do you guys Think its a trigger error. If it triggers 1 Point wrong in 1 RPM it will break up bad.
So is it external (tach) or is it also internal (log)?
That's a good point. Maybe it's just a laptop/ECU/Datalogger issue.
Discussion Starter · #13 ·
It reads correct 95% of the time
Discussion Starter · #17 ·
Just went out to work on the car and it is still doing it, I am thinking about putting in the holley 3/4 16 hall effect sensor
Just went out to work on the car and it's still doing it, I'm thinking about putting in the Holley 3/4-16 Hall-Effect sensor
You'll have to change the target (trigger wheel) too.
Your (red 12mm) Cherry Hall-Effect sensor is a geartooth sensor, which senses a ferrous steel tooth target.
The Holley 554-118 Hall-Effect sensor is a magnetically operated sensor, which senses magnets in a target.
Discussion Starter · #19 ·
I already have a flying magnet with the cherry sensor, we have ran that setup in other cars and cant figure out why it doesnt like it. I will be ordering the holley sensor this weekend
1 - 19 of 19 Posts
