1 - 6 of 6 Posts
Changed out fuel lines and engine won't stay running in the past my fuel pressure was at 7 lbs and always held there when pump was turned off and now will not hold pressure. Is this OK or Not engine will start but won't kept running is this a bad pump or regulator??
I cleaned out the carb ect. Just don't know if my pressure is ok.like I said when the pump is turned off pressure drops quick on the guage or is it electrical but it starts just won't idle or rev.
Sounds like a bad Vac leak or intake leak ...
Check for a stuck needle and seat and check ur float levels, check that the choke is not closed. Visually check if u have fuel squirting in the carb, check idle. What did u do to the carb exactly, what did u take apart?
1 - 6 of 6 Posts
