1 - 7 of 7 Posts
I'm putting motor plates in my car. I'm thinking about setting my engine back approximately 3.5 inches. That would put the number 1 spark plug 2 inches behind my front spindle.
My car has the factory subframe, 8.50 cage, 29.5x10.5 slicks, and about 3500 lbs.
Anyone with a similar car have experience doing this? Was it worth the extra work? Pics would be great if you have them.
Anytime you can move front-end weight to the rear end, that's always a plus. Unless you are making gobs of HP.
That said, are you going to modify the firewall?
I moved the engine back about an inch in my Nova and that's all I could do with a stock firewall. Sure caused a lot of fitment issues for only an inch.....
I'm assuming a small block ???
My chassis guy pushed my engine back and up one inch both directions for a front and mid plate BBC(69 Nova). I have not idea why he did it but I trusted him. Car works good. I did have to cut an access panel in the trans hump so I could get to the bell housing bolts. Was not a big deal...I had a couple of junk parts cars so I just cut a panel out of one of them.
This is what I have generally seen. Unless you are doing the whole front end to go with it, moving the engine back only creates more issues.
Discussion Starter #7
I ended up not setting the engine back. Once I started test fitting the engine with the midplate on, I could see I was going to have to cut up the firewall more than I was willing to.
Thanks for the help.
1 - 7 of 7 Posts
