I know a lot of people on here have dealt with and seen a lot of engine failures over the years. I figured this would be a good place to ask opinions on these failures. Thanks for any and all input :supz:
This is an import engine. Specifically a Mitsubishi Evolution VIII.
Two engine failures in two months. Below are the two engines and some details. The car is running on pump E85 fuel.
* Engine One (1)
- JE 10:1 pistons (standard wrist pins)
- Pauter rods
- Clevite bearings
- ARP L19 head studs
- ARP main studs
- Modified balance shaft
- Stock crank pulley
- OEM non turned crank
- OEM oil pump
- Brad Penn 30 grade break-in oil
- Brad Penn 20w50 grade oil
Multiple pulls at 38lbs of boost. Everything was fine until afterwards. Driving normally thirty minutes after tuning the engine started knocking. It ended up being number one rod bearings had completely spun, number one bent wrist pin and locked oil pump.
Duty cycle: 74%
Air:Fuel: If I remember correctly was 11:1
Air temp peak: 109*
* Engine Two (2)
- Different low mileage block
- Different low mileage crank
- Cleaned oil cooler
- JE 10:1 pistons (upgraded wrist pins)
- Manley Turbo Tuff rods
- ACL Race bearings
- ARP main studs
- ATI crank pulley
- No balance shaft
- OEM non turned crank (52,000 miles)
- OEM oil pump
Duty cycle: 75%
Air:Fuel: If I remember correctly was 11.5:1
Air temp peak: 79*
The second engine developed a slight knock after only two pulls on the street. The second engine at partial throttle / vacuum the knock sensors were very noisy and going into the knock map. Number one rod bearings were barely spun but rod wasn't discolored. Number two, three and four rods bearings were completely spun and the rods were discolored. A plug on the oil pump was also discolored as well.
* Setup
- Front face exhaust manifold
- Precision 6765 turbocharger
- Garrett intercooler
- 3" open downpipe
- AMS intake manifold
- Injector Dynamics 2200cc fuel injectors
- Bosch 044 (2) fuel pumps
- Weldon A2040 fuel pressure regulator
- Weldon fuel filter
- AEM EMS Version 1 standalone engine management system
- Brad Brooks crank trigger
- Spark Tech Non-CDi COP Systems
- NGK 8 heat range plugs
- Catch can (two -10 breathers off valve cover)
- Ferrea valve train
- HKS 272 camshafts
Both engines the plugs looked fine. No metal flakes. Didn't look to be hot.
* Engine One (1)
- Pauter rods
- Clevite bearings
- ARP main studs
- OEM oil pump
Duty cycle: 74%
Air temp peak: 109*
* Engine Two (2)
- ACL Race bearings
- ARP main studs
- ATI crank pulley
- No balance shaft
- OEM oil pump
Duty cycle: 75%
Air temp peak: 79*
* Setup
- 3" open downpipe
- HKS 272 camshafts
