1 - 10 of 10 Posts
The last 3 times out with my blazer, the engine keeps breaking up and the aem a/f gauge shows it going fat while doing so. Engine is a 357 sbc, 10.2:1 flat tops, extreme energy 274 cam, rpm air gap intake, qft 750, 1" carb spacer, msd ignition, 91 and up octane. Engine does it around 4500-4800 rpm, then cleans up and runs right. End of last year it got new cap and rotor and msd coil, last week put new plug wires
Almost sounds like there's a groundstrap closed up on a plug ....Go thru the plugs & wires again, maybe a wire is arcing off
make sure the engine is properly grounded. run grounds from both heads to the frame. this solved a similar problem I was having. Engine would miss intermittently at around peak torque, then clean up some. an old wise man told me it wasnt grounded well enough even though I was using solid mounts. 2 simple wires from heads to frame totally solved it.
It's grounded with a jpegs ground strap from 1 head to frame. Other side has a turnbuckle and chain from head to frame. I went threw plug wires 2 times.
With front and rear motor plates, are ground straps still needed for the heads?
Alluminum is not a very good conductor .... If the mid plate is a steel one, I'd say you're good and perhaps another strap off the front
They are aluminum plates. Might as well try that next. Tried just about everything else short of changing the box and it's replacement is on the way.
If you have an ignition miss fire AF will go lean on the bank with miss. If it's going rich you have too much fuel.
?? Aluminum is not "as good" as copper as a conductor. However it is much better than steel/iron. Aluminum has been , and still used for wire in many instances. When was the last time anyone used steel or iron for electrical wires?:confused:
1 - 10 of 10 Posts
