1 - 5 of 5 Posts
I am going from an 8/71 Enderle 110 setup to 14/71 990 with a flowed tune. Will the an12 inlet with the returns plumbed straight into bottom of the inlet (loop) flow well enough? do I need to go -16? The outlet is -8.
TIA
540, 14/71, B&U 5 9/16, 2900lbs, shooting for 4.30 to 4.50 range......
are you selling the 110?
personaly I preferred sending the returns to the tank so it would not disrupt the flow at the entrance of the pump and cause turbulance or air at that point. I think you can flow plenty of fuel through the -12 line. Larger would probably be better, but you can send alot of fuel through a -12
1 - 5 of 5 Posts
