1 - 7 of 7 Posts
Looking at having an enclosed trailer built that can double as something you can have at the track and be comfortable sitting inside out of the heat. This is really a smaller is better thing for me (no toy haulers) because currently a 24' trailer is all i have and it's too long for me to want to hook up to if i want to get a bunch of lumber at home depot for example (truck bed isn't really an option).
Really wanted like a 14'x8.5' trailer but the salesman is telling me the generator box takes up a bit of interior space so now I'm thinking 16'. Should be long enough for lumber and long enough to fit a few bikes in.
I'll list the options I'm looking at below, what i need you guys for is to tell me what it is you really wish you had or have in your race trailers that'd make life a whole lot easier while hanging out at the track or something i could camp in for an evening or two, that i might not have thought about. Please keep in mind i don't want anything longer than 16'
Thank you!
  • NEW 8.5x16 Tandem Axle Covered Wagon Cargo Trailer w/ V-nose, White or Black, (2) 3500# Axles w/ Electric Brakes, 6'6" Interior, (1) LED Interior 12V Light, 36" RV Style Side Door, Ramp Gate Rated at 4,000lbs, 1 Piece Roof Upgrade, Radial Tires, LED Lights, 3 Year Warranty on Trailer, 6 Year Warranty on Spring Axles, 5 Year Warranty on Tires, 1 Year No Excuses Tire Warranty - $5,199+TT&L
  • 7ft Interior Height Upgrade - $200
  • 5200# Spring Axles Upgrade w/ 225 Radial Tires - $600
  • Upgrade Axles to Torsion Axles - $400
  • 13,500 BTU A/C Unit w/ Heat Strip, Wiring and Bracing - $1,200
  • 30 Amp LED Electrical Package - $400 - (2) LED Lights, (2) Outlets, Light Switch, Breaker Box, 25ft Life Line, 30Amp Plug
  • 36"x30" Generator Door w/ Venting and Box and Lockable Door - $725
  • 12" Centers in Floor Upgrade - $160
  • Upgrade Ramp from 4,000lb Ramp (Standard) to 7,000lb Ramp - $350
2 wheels,no cage,250mph
can you mount the generator on the A frame ? I've seen it done previously.
Currently I have a 6x10 & 8.5x20 for the bike or sandcar. Many times I wished both were bigger, but I make it work.
If nothing else make sure to get torsion axles!!!
Generator & A/C would be a plus.
Never cared for the v-nose deal, almost a wasted 3-4 ft unless you build a workbench & cabinets in the nose.
might want to consider a tinted window on pit side so you can see your stuff & a roof vent w/ built in fan.
The V is a good place for a home made shower
Thanks for the replies guys. Currently quoted at $13xxx plus ttl for the options i want. I guess i might as well see how much more a comparable ATC trailer costs.
1 - 7 of 7 Posts
