This will probably be an easy question for most of you. After different searches on here and google I've found I can swipe an electric vacuum pump off a ls1 engine. To make this work I saw on here after a search an oil cap piece I can to run a hose from the valve cover.
Anyways to shorten this down what all do I need to make this work? This is going on a street car and I'd like to run it all the time.
