1 - 20 of 38 Posts
JACKASS
What is the Bullets opinion on electric fuel pumps.
Edelbrock 1406 carb, street driven everyday driver.
Nothing fancy, stock SBF, just looking for a reliable electric fuel pump.
I have the fuelab 40402 (needed inline do to physical space requirements) running on low speed unless nitrous is activated. If I didn't need a bigger pump I would have just stuck with mechanical, though I am perfectly happy with the electric pump.
mallory comp 110, nice and quiet, no need for a reg, perfect for a mild dailey diver
Horsepower and Hops
I used one of Holley's HP pumps on a customers car recently. Nice piece, and fairly quiet. Just say no to the older Holley Red/Blue/Blacks.
Premium Member
Maderator
If your set on electric OP the Fuelab stuff is the way to go..... Call them @ 618.344.3300 and talk to josh or Brian.... They will design a system for your application and budget.
I have the Carter Black pump in my 68 camaro that feeds two 600 Holleys on a SBC tunnel ram. LOUD AS HELL! But never loses pressure. Its a rotary vane pump, easy to fix.
The Aeromotive street/strip pump is great and reliable for your application.
What was their determination on why it was failing? Did they take care of it for you?
Yes they took care of me every time but wasted a entire car season because it would fail going into high speed intermittent. By some magic it didn't kill the motor going lean in boost.
Maderator
What were you using for a trigger to change speeds? I only ask because very very rarely would that be an issue with the pump, usually it is a external wiring issue. All of their pumps are dyno tested with the results and flow numbers provided to the purchaser.... It seems like that would have been caught before it left especially if it happened more than once.
1 - 20 of 38 Posts
