I use a 250amp continuous duty solenoid mounted within inches of my battery... (behind cab in bed area)
I ran my battery cable from the battery to the "hot side" of the solenoid, then off the other to my main distribution block inside my truck, where the starter solenoid gets its power from...
I then ran a 10ga wire from the "hot side" to the rear of the the truck to a 50amp push/pull switch mounted in my taillight area, then to inside my cab to my gauge panel to another push/pull switch and back to the solenoid to energize it...
Both switches must be on (pulled) for the truck to have power, but either will kill it...
Saves a lot of weight on battery cable!
I also use RJ Race Cars light weight cable...
