Finally pulled the trigger on going EFI after 2 yrs on thinking about it.... This is a 615"BBC with (2 dry systems) with Holley Dominator ECU. Using Holley smart coils, using old MSD crank trigger wheel, Hall Effect sensor, & "EFI CONNECTION unit" for cam sync. As seen in the photos right now we are setting up base timing around 28*.
Hall Effect is aligned the magnet. Question is with the cam sync.....When dropping the shaft in, should the sensor at the base (center of wire harness plug) be aligned with the center of the "overhang" of the wheel as seen in the pic?
Also.......not clear on digital rising or falling.
Thanks for any help with this set up procedure ...Ray
