Moved the battery to the trunk and this is my first time wiring a switch with an efi set up. After much reading, I’m a little lost.
It sounds like people were losing tunes in their ecm if the switch was flipped or burning up ecm’s from a voltage spike. I’ve got a 145 amp truck alternator on the car. I’ve also read people using the field wire to the switch instead of the charge wire on the alt.
Which switch should I use and how do I wire this thing correctly so I don’t burn up the alt or computer? Thanks for any help.
I was looking at the flaming river 6 post (fr-1013) that is rated for 150amp continuous and grounds voltage spike as a safety through a resistor to ground.
