so im new to the E85 fuel my question is we just tested some fuel and it test out at 92 now what is that going to do to the tune? not being 85% is this going to cause a problem and what happens if it test out say 78% what will happen there.
Not much at 92 it might be just a little lean and all you need to do is add a little bit of 87 octane fuel to it to get dwn to E85 and as for 78 it will make your set up a little fat, So if you some 98 just add a little to make 85. I have run as low as 72 and not had a problem.
