1 - 3 of 3 Posts
Was just wondering what the shelf life is for e85 fuel, I have had a barrel for about 2 months, any help would be appreciated
I have read and been told it lasts a long time and that the percentage of ethanol can increase while sitting, due to the gas evaporating. As long as the container is sealed so no moisture can get in it, then you should be fine. No expert here just been learning about it myself.
I have herd the same. I have mine in a VP drum. so I will check the % in the spring. Drag chevette on here is good on E-85.
1 - 3 of 3 Posts
