1 - 8 of 8 Posts
I have a magnafuel 500 pump 12an from the cell to the pump and a 10 feed and return with 8s to the bowls will this work for e85 on a blow through set up?
It should. Thats alot of volume capability youve got there. Line sizes are great. As long as the pumps good. I dont know the specs on it.
The set up is a gt55-91 on a 383, I have the carb from c&s that I was hoping to send back this winter, just didn't want to redo the fuel system
You'll be fine to 1100 no problem. I went over all this with their tech support and he came up with 1400hp for the 750 using a 16V but that was @70psi base pressure and running 45# of boost.
Looks exactly like my fuel system. Add a 13202 reg & CSU BT 850 and your there. Magnafuel told me that system could support 1400h.p. with E85.
1 - 8 of 8 Posts
