1 - 3 of 3 Posts
I have a 1996 powerstroke with the E40D in it, truck has intake, exhaust and chip. I was towing my car home when the trans acted like it came out of gear. Now I have no fordward gears but the acts like it will still go in reverse. HELP..... What should I do.
pull the trans pan and check for alum if it does take apart and check to see if the forward planet is alum if it is it may have striped its splines on the output shaft if not check the forward frictions
Most likely stripped the splines in the forward clutch pack. This is common. If you leave the wavy steel out in that drum you can add one more clutch and have a way better forward apply. They also sale clutches with hardened splines. Make sure to put a V.B. kit in it I like the Superior for the E4OD but the Transgo works great too. As long as your "chip" does not add more than 100hp you don't have to go crazy on a bunch of updates.
1 - 3 of 3 Posts
