1 - 20 of 42 Posts
DEBATING ON E 85 CONVERSION.
SBC 406 ALUMINUM HEADED.
WAS THINKING OF SWITCHING OVER TO E 85?
UR THOUGHTS?
WHATS NEEDED BESIDES FUEL PUMP AND CARB?
IS IT WORTH IT?
ENGINE IS 10.1 COMP
THX
"Shocks don't matter"
UR THOUGHTS?
IS IT WORTH IT?
ENGINE IS 10.1 COMP
THX
If methonol became extinct, I wouldn't go to gas.
Positive response has been high.
I have had great results so far with e85. Way better than gas in some ways. Performance on par with race gas in some situations with 1/4 the price.
10:1 it's not really worth it, stick with 93, unless you plan to spray or use a blower.
What do you have, now? you might not need a fuel pump, and could have your carb converted.
And I run the hell outa e85:p
Unless you up the compression or add blower/turbo/N2O I wouldn't bother.
Discussion Starter #8
yes I have a plate system gonna use it
fuel pump is a bg280
no blower
thanku
I love the stuff. I run a BB Mopar with a 1050 dominator and magna fuel 275 pump. So you should be OK with a carb conversation and the pump you have.
That last weekend we went to play, I was filling my gas cans at $2.48 (IIRC) for E85, and next to that was a 110 pump for $7.80...
That's why I switched. Similar setup to you. SBC with a plate system
Same here.... It was the cost savings for me.
no blower
thanku
Go for it, then! pump should be good. Get rid of any paper filters, and go with stainless.
Drag Week Survivor
I like E85 over 93 pump gas, but availabilty is the limited where I live.
I switched my wife's 14:1 sbc from C-12 to e85 and it was saving money every race weeked, but I had to go out of my way to get the e85 and it became a pain in the ass.
From my personal experience, E85 is a great choice if it's readily available.
I am not sure you will feel much difference on a 10:1 pump gas engine like that.
this i was told by mark it wouldnt do anything for it,except run a little cooler ,he would like more comp. in my engine which is also 10.1 ,and he said use as large a fuel pump so i never need to change:rolleyes:
You are right on a n/a 10:1, but a nitrous 10:1 is getting into race gas territory. If the op is using nitrous once a year, run pump gas, and dump in some 110 on the nitrous days. If your using it all the time, E85 would be a nice alternative.
Mark told me the same thing about my pump. The carb builder that built mine told me to start out with the pump I had... 3 years later the lil black pump is serving me well:p
On a 11:1 motor, going from 93 to e85 was worth .2 and 3 mph Na
motor would run 200-210 in the heat on 93.on e85 I had a hard time getting the motor to 180* on a 90* day.car would run consistent 11.40'at 122 and dropped to
11.0 and the occasional 10.90 at 125.with nitrous it picked up a bunch and ran a best of [email protected] on a basic head and cam 351w
I started running e85 starting this year as a way to cut cost and it has done that in my opinion if you can't build your own carb I would go to meth.I built mine with QF metering blocks and it was a challenge not a bolt on and go.If your gas carb is tuned well don't expect a big pick up and search e85 black goo.It doesn't like moist air at all.
Wayyyyy more left in it!
E85 makes an amateur tuner like myself "look" like I know what I'm doing. For junkyard turbo ls, it's the only thing I feel comfortable with, but every setup is different.
depends on your cam and chamber.
weak combos like e-70 better . if your car is set up to spray e-85 will make a world of difference in N/a .... the tighter the combo is off of ideal N/a the better it will work .
have not seen a 9 second or slower combo that a tune up did not run better !
1 - 20 of 42 Posts
