1 - 20 of 22 Posts
on a stuska dyno(sp) my junk made 535hp @ 6500 rpms it is a 377 sbc heres the run down 4.155 *3.48 13.8-1 dart race series220 heads std port flows 298 @[email protected] super victor 1000 cfm pro systems stage iv custom ground comp cams aprox specs 272 280deg .730 .740 on a 108 the dyno headers they used were 1-5/8*3 I am going out there in the am and we are putting my headers on which are 2"*4"with dynomax bullets can i expect any gains? thanks Glenn
I am going to say yes. I have seen a header change pick up 20. This thing has a monster cam in it whitch I think may be throwing your combo off.
well i was thinking it should be making 100 more hp mabee the numbers are uncorrected something seems off to me the cam i had in it before was way wrong..........and according to hp/et calculater made 521hp...................ill post the sheet tomorrow. Glenn
Yes I think it's down on power also something is just not happy. I think RPM is on the low side also for this size stroke. I would want to see upper 7s to lower 8,000 RPMs for peak.
The heads dont flow that well, why worry what the .800 number is your not even getting close to it. Look at the .500-.600 numbers. The 2 " headers with a 4" collector is way to big for it, carb looks big too. Your not going to see any big change. I dont think and I think TQ will fall off too post your sheets. Cams can be way off on these style motors and it will mean 30 hp
thanks the head # is the only one i remenber, I agree we are going from to small to too big im probably being optimistic when i can afford a set of 13/4 to 17/8 step header they will be there. comp speced out the cam according to everything else.................its kind of depressing I could have bought a really nice proven crate engine for what i have in this thing.
I think your cam is a good choice if that is the true comp ratio...
It should be making 635HP not 535
My 358 with sportsman 2 heads 13.6:1comp and 278/286 on 109 make 655HP at 8100rpm, just to give you an idea and i have 1.75 primary pipes
Drop the duration down 8-10 degrees tighten lobe sep.to106-107 .lift is ok.use 1/3/4 header.are you absolutely positive comp ratio is 13.8 or is that a guestimate?Bill C.
Discussion Starter · #10 ·
thats what it was before this rebuild the deck was surfaced and different head gaskets are used so it could be off .2 or so i will get cranking psi tommorow as well!
Discussion Starter · #11 ·
also heads are 55cc chamber dome is plus 5cc including valve notches deck hight was-.008 before the surface cut cant remember the vol of the mls gaskets from before...............
Butch
I would keep the duration and go 104 to 106 based of prior performance
We are making more than that shown by ET's with a GM crank, 5.7" rods, TRW pistons and as cast Dart Heads from 30cid less or so (4.030 x 3.25)
Discussion Starter · #15 ·
Thanks for all the replys with the 2-1/8headers &4"bullets it made [email protected] from6700-7100 it was gaining 10hp per 100rpm we ran a last pull up to 7600 but the collector came off the compression is only 12.5-1 and the bsfc was all over the place and also it wants more carb going fat above 6700rpms......................I will not have the sheets until i pick up the engine tommorow or friday i will post them then I am pretty happy with my junk heads carb and headers..........................
Discussion Starter · #16 ·
my carb is not junk because of pro systems its junk because it has been 10 years since i got it and it hasnt been back since
My 379 c.i. small block made 649 [email protected] & 509 [email protected]
My combination is 4.155x3.50 11.5 to1 comp. 93 octane pump gas. Track 1x cylinder heads [email protected] int [email protected] exh .660 lift with 1.6 ratio rocker. Dart intake and Holley box stock 950 carb. Using 1.875 primary tubes & 3.5 collector. Also the cam is on a 107 lsa. Book grind from Comp nothing fancy.
This is proven power, My 3150 nova has been a best of a 9.72 at 136 mph with 1.27 60 ft.
Discussion Starter · #18 ·
Thanks Heath Im going to put it in and see what it will do! And the start refining it one thing at a time. What gear tire & trans do you run? Thanks Glenn
I run a 4.88 rear gear 30x10.5 Hoosier radial slick turbo 350 trans with brake. Goes through between 8400to8600 depending on weather conditions. Also running a 6200 stall speed on the converter. You really have to rev these short stroke engines but I love how they sound!!!!
Butch
Glen that is a couple degree's smaller than what I talked to you about
1 - 20 of 22 Posts
