1 - 6 of 6 Posts
And any input is appreciated....
I have a single 106mm with a single 60mm gate. I have manifold pressure plumbed to the bottom of the gate and to the bov. I have a 2 lb spring in the gate and I have a adjustable regulator for compressed air to the top (which will be c02 and a boost controller)
Am I correct in thinking that if I add 1lb of air to the top of the gate that I will get apporx. 3lbs of boost and if I add 10lb to the top of the gate that I will get 12lbs of boost? Is it linear, or does it take a ton of air pressure to overcome the gate?
I dont have a air pressure guage on the regulator? Should I add one?
This is a blow thru deal and any pointers are much appreciated!!!
Custom Engine Shop
Depends on back pressure in the hotside. Most back pressure more pressure to control the gate.
What kind of boost controller?
I am going to use the msd unit once its in the car. but for the dyno im just going to use the regulator with compressed air on it
TURBOBULLET.COM BITCHES!
? I guess no one here Dynos their shit
Robert's statement pretty much answered your question...
Better be ready for 4000HP:rolleyes:
If it was me on the dyno I would up the spring pressure and not use a controller..maybe a bleeder feeding the gate and just use boost pressure to control gate.I would keep it simple on the dyno.
1 - 6 of 6 Posts
