i lov it but getting to old now so let it go. 350 7000 rpm motor 5 speed doug nash mr . gasket vertagate shift ported alumunum heads in take an carbs 2 hi per hollys carbsh beam rods forg steel crank 4 bolt mains all oil tricks steanles headers , manuwel qwieat or rasceing louwd exzost / cut outs there called open headers if disierd all of car work when stord glass mint all body trim an intera there exsep door panel an head liner i have spar parts that gos with car [ i will take all my thing out of car ] junk thats min ; rear an trany have grat ratio fast so be a safe driver bracks duwel master an all around drum brackes sold state altnator no termastat alumnum ratator car runs pefick in hot days car need carb over hall sitting primaerys an car need front sway bar on street , hot ignition system .have arm rests front all handel an nobs]
I can never open eBay links from my phone. Not sure why? So, I’m quoting it to see if that works. Used to work for some...
