For those running a dump valve: Is this a kit from a trans builder? Or did you create your own? Care to share how these are plumbed? I have heard of some that don't dump much, and others that really allow the engine to spool quickly.
Prevent thrust bearing failure.Super helpful! But now I am curious about the one with the regulator set to 75 psi. What is that for?
Yes, as soon as it's making enough power to get up on the converter kill the solenoid. While it's dumping you are creating heat and reduced lubrication in the converter.
Why is the T on the line IN ?Well crap I found instructions on Summit right after I posted.
https://static.summitracing.com/global/images/instructions/fti-f4065.pdf
