1 - 7 of 7 Posts
Busy being a cunt
What are you guys using for a dummy shaft to fit a 101a(18 spline/1.170)to a Chevy engine(.590 spigot)with twin plate clutch?
Busy being a cunt
I have mine dummied up at the moment without a spigot bush in place.
In the interim i might get one made, maybe 2 if the price is right :)..........which I doubt as Australian Labor rates are so high :(
Ok, so does it need to be anything special? Just a 1 3/16" 18 tooth Chrysler spline with .590 pilot? Can you use a used input shaft? I have a damaged Nash/chevy one, the snout is currently broke off. I've been thinking of just basically tacking the snout on for use as a dummy shaft.
slams revolving doors
Turn down a Chrysler one. The pilot size is bigger so it can be used.
Ford is larger also(.669) so it could be turned down also.
1 - 7 of 7 Posts
