I think alot of you turbo guys run dual rear calipers on the back so you can hold it while you spool it.....I have 88 fox body mustang anyone got any pictures of this set up or a part number to a good place to oder this????
I'm not sure. I had singles and then I upgraded to duals a few years later. I can hold the car with the foot brake making 13lb of boost at 4,600 rpm. I hear the Strange brakes work better and you might get away with a single caliper. I had Wilwoods already so I just bought a bracket and a second caliper.what kind of price on the duel wilwoods???
Any advice? Mine moves just a little bit on the footbrake.we have dual rear aerospace on our car...i am a dealer for them and can tell you from experience what you have to do to make sure your car dont budge
chad
813-784-8248
$2000 for the whole setup. The the Aerospace rotors are used, but all 4 calipers, all pads and mounts are new. The 35 spline axles and spool are brand new also. The axle tubes are braced from the front side. It has a 3.55 gear, but I can put whatever you want in it. Mark Williams yoke for a 3150 U joint and a T/A cover included also.how much for rear end and all??
sorry for the slight hack on the thread, but you might wanna put a big friggin' washer or something on the upper control arm heim joint on your rear if you're putting any amount of power to it.I run Aerospace. I've a complete 35 spline 8.8 for sale with a brand new dual Aerospace set up on it. The set up in the picture is on the 9inch in my 93LX.
You have a good eye for detail. As I'm sure also noticed, there are no coilovers brackets welded yet either. That was all in the mock up phase. I actually put 2 thick washers on the outside of each heim joint to "capture" it in the event of failure. Also, I didn't use those heim joints. I upgraded them to QA1 moly heims. However, I appreciate you looking out for the safety of a fellow racer.sorry for the slight hack on the thread, but you might wanna put a big friggin' washer or something on the upper control arm heim joint on your rear if you're putting any amount of power to it.
