1 - 8 of 8 Posts
im putting a th400 together using a tsi rmvb
It says to remove the lip seal in the drum
But nothing about removing the ring off of the centre support to dual feed
Should i do this and which hole on the centre support should be blocked for this mod so i can check its done in the seperator plate?
Thanks ben
Thanks ben
The hole to the right of the bolt
Also when checking the input shaft endplay
Do u put a screw driver in case and pull it towards the rear of trans and set to 0 and then lever to front to get a reading like a crankshaft ?
MFI on CH3OH
163987
This is a great book to have. Has all the fundamentals for doing a rebuild in it.
  • Like
Reactions: Gregaust
Just leave the seal out of the drum that way the wrong ring won't accidentally be left off the center support. Nothing has to be plugged unless the directions say to do so.
Hutch
Discussion Starter #8
Thanks guys i have that book but im a dumb ass boilermaker lol sometimes just need clarification on certain things
1 - 8 of 8 Posts
