Hi everyone,
Im building my first drysump engine and is experiencing some problems… wonder if there are someone inhere that can guide me in the right direction…
I have a few routes that i think could lead to the problem, but i will give you the blank sheet so you can make assumptions for yourselves😊
Problem is->
Oilpressure is fading from the bypass valve pressure 90psi at mid rpm… and gradualy down to 40 ish psi at 7000rpm (95 degressC oil temp)
It have good oil pressure 50psi at idle (1300 rpm)
Tried to measure pressure before the oilfilter, and i saw 12 psi higher pressure on the dyno run, i have ordered a KN 1003 filter to see if that improves the flow, but i would still like to see the presure even higher
First dyno session was on 10w-60 oil where i was suspecting the feed hose was collapsing and there fore causing the pressure to fall…. I got back home and installed inner springs in all vaccum and feed hoses, and ran 5w-50 to see if that helped…. Feel like it was a bit better second dybo day, but still no where near the 10 psi/1000 rpm rule
Let me hear what you think?
Info:
Pro drift spec BMW E92 M60B40 4.0 v8 quadcam full aluminium engine turbocharged. Hp goal 700-800 crank hp 1000+ nm 7500 max rpm..
Drysump setup out of a Aqilia m60 racecar. Have tried to run both 10-60 and 5-50 oil
Pump drive ratio 1.2 (seems low to me)
1 pressure stage, 2 scavenge stages.
Drysump tank out of a nascar, sitting in the rear seat, holding 12 quarts of oil
-16 to the flywheel, then 3 feet -12 to the pump (pump have -12 inlet size)
-10 to oilfilter -10 to engineblock
-10 from sump to scavange
-12 from pump to air/warter heat exchanger
-12 to oiltank…. Scavance hoses + suction hoses from tank to pressure stage have the Earls internal spring fitted so it does not collapse from vaccum…
Best regards!
Problem is->
Info:
Best regards!
