Evening, I have a 430 cubic inch Donovan aluminum block with SB2.2 heads and nitrous. It has a Petersen 5 stage R4 pump but I need a tank and breather yet. What size do you guys recommend? I have a line on a 3 gallon petersen tank and breather for cheap and my understanding is you fill it 70-80% so say 2.25-2.5 gallons of oil for the 3 gallon. It is 9" diameter x 16" tall. I realize its a little large... but its cheap im not married to it but figured if it is where I should be why buy new.. Whats the consensus on this? Its in a 88 mustang notch with tube front end so if it comes down to space I'm sure I can accommodate it. Thanks
