1 - 10 of 10 Posts
Has anyone here used the Jancy dry cut saw and if so what are your opinions of them ? My space is limited so I feel this could be the best solution until I have room for a bandsaw later. Materials to be cut are steel, moly, stainless and aluminum, I understand there are blades for different materials and I’m not worried about that.
I did find an old (pre jet) Wilton 5x8 bandsaw that might even be a USA made model, however I am running out of room quick in my Garage with all the new equipment I have been purchasing. Waiting to hear back from the seller for more details on that.
Benders : I am looking at the pro tools and JD2 units. Which would be preferred for power assist, hydraulic or air ?
I am gearing up to take on my own project which consists of the turbo set up and more than likely a 25.3 cage. My intentions are to obtain the tooling needed for now and possible side work in the future.
Dry cut is a bit advanced for what you need where a regular portaband and tube notcher would work well. I have ironton dry cut and a harbor freight esq bandsaw that I use much more than the ironton, but its 1400rpm blade not true cold saw so metal flies everywhere. Chips. Pieces cut off end etc.
I have the model 32 jd squared bender with a air over hydro set up I have a few friends with the same bender also so we borrow dies if need to. I have a porta band with a swag table a bench top belt sander I build a few cars a yr and have no issues I use my chop saw and I also own a band saw but use the chop saw more
I have the rogue fab notcher and it is solid. I have absolutely zero complaints notching 4130 chromoly with it.
I have a Makita cold saw with a carbide 12” blade. Works great but you have to clamp the tubing in tight or you knock the tips off the 150$ blade. I use a chop saw for the stainless header tubing. Pro tools bender with hydraulic ram. I’ve had it for 20 years and it still works like new.
Also pro tools ultimate notcher that notches whatever you put in it including titanium
Discussion Starter #8
get the best tube notcher you can afford or at least one with a large main shaft its helps with deflection
I bought a TN-250 recently. I also have the Milwaukee portaband and swag table. It’s fine for a few cuts here and there but I wouldn’t expect to complete an entire project with it. After many years of using chop saws with abrasive blades I can’t stand the smell and dust anymore.
Discussion Starter #9
Air or electric over hydraulic ?
1 - 10 of 10 Posts
