1 - 2 of 2 Posts
[email protected] JoeCool Performance
So assuming that I have the header and oil pan clearance to use .75 drop mounts will I also have to drop the tranny mount to match or can I get away without any other changes? I need to drop the engine to make up the room that I lost from going to a thicker nitrous plate. Thanks
Joel
The biggest affect it will have on the tranny is the driveshaft angle, may have to reset the pinion angle. I usually try to have @2-4* angle in the motor at the intake plain depending on the setup.
1 - 2 of 2 Posts
