1 - 4 of 4 Posts
i just got my new driveshaft put in the car. I have a powerglide and yesterday was the first time the car had ever moved. I went through all the gears checked the fluid levels. Everything was great, sat the car down and went to push it out. nothing. After checking rear brakes then rear pinion and ring i realized the driveshaft was siezed in the tailshaft. Has anyone ever had this happen, what should i do?
For some reason the yoke and the bushing didn't get along. Undo the bolts on the housing and pull it off with the driveshaft then beat it apart and start over. maybe the bushing was too tight , installed dry? shitty finish on the yoke? Start over and make sure you address those issues.
Hutch
1 - 4 of 4 Posts
