1 - 14 of 14 Posts
YB Managing Editor
My old gear is a 4 series and the new one 3 series. But i can´t make it fit with a new spool. Becuase the pinion is moved in my high ratio case.
3 series ring gears are thicker than the 4 series ring gear.. This is why it won't fit.
You can put some 4 series gears on 3 series carriers with a spacer plate but not vice versa.
Now i have more info. I had a 4.10 richmond PN 79-0011-1 4 series gear before. The one Driveline solotions sent me is a Motivegear D60-373 (2 series?). Motive have a gear with PN 708125-4 (4 series?). Could it fit with the other gear??
Did it even cross your mind to call them???? They sent you the gears, so CALL them instead of dragging it on here....:rolleyes::rolleyes::rolleyes:
1 - 14 of 14 Posts
