1 - 16 of 16 Posts
· Registered
I hope this isnt to talked to death about...
I have a turbo sb 92 stang, made 801 to the wheels, stock susp.. right now I have a 27x11.50x15 hoosier Quick time pro tire, they are about a year old(probably hard by now). I was at the track(mir) a few weeks ago, (first time out this year since converting to turbo) I launched on the first run at 3800 and fried the tires. had about 11.5psi in the tires. I am guessing I need new tires and was wondering if i should go with a drag radial (275-60-15) or go with a full on slick measuring the same, or a radial slick? I really dont have a class that im interested in( i ran the real street @ MIR) to run that class I would need a drag radial. I am no where near being competitive in the class , as I am hoping for the best traction. What would you guys recomend?
· Registered
Hey Steve, I see you went turbo. How do you like it and what size turbo do you have on it?? Ive got 2 turbo kit's and havent used either one yet. I changed from the YSI to a F1R this year and Im making less power than I was last year. Im about fed up with the blower's and just need a little inspiration to put the turbo on it. Let me know what your combo is and what turbo kit youve got on it. Your ride must be screaming. Good Luck.
· Registered
So far I like it. No belt to deal with. I used an s480 bg turbo. 80mm. right now i have maxed my injectors out, they are the RC 750cc injectors, real nice but maxed out. I am only pushing around 18-19lbs of boost. I have traction issues, thats why I need some advice on tires. 1st run out i fried the tires real good had to get out of it and ran 151mph at the end but was only a 9.71. 60 fts. were shot.
· SOFA KING WHAT?
Your are legal to run the 28 X 10 slick at MIR, I saw the car there at MIR, man it's clean!
I've had great luck with the hoosier 275 drag radial, but the 28 X 10 stiff wall slick recovers much better and will work on a marginal track.
· Registered
Discussion Starter · #8 ·
Thanks for the compliment! It looks like I am leaning toward the hoosier dr. I was alittle concerned about how much the tire grew at the end of the track with just a regular slick(i have the cobra ground fx) and the tire would probably rip off my side skirts. Thats why I am leaning more to the radial, being a dr. or a slick.
I am trying to get a couple of things figured out before the next real street race in sept. it was real wierd, first run went good other then the wheel spin, 2nd run, 1 of my spark wires was just hanging there like it was pulled off and also i blew my power brakes out(vacuum line came off). ? i zip tied everything and now swaping plugs+ a few other things.
· Registered
Discussion Starter · #9 ·
I also email'd jason about running a slick, he said with what i have , i have to run a dr.? also thats what the rules say.
· SOFA KING WHAT?
Sorry, was thinking of the NOS SB rules, not the turbo rules about the tires. I had the same issues that night with the car working and then blowing the tires off of it (old set of 325's). I love my 275 Hoosier tires, went 1.37 60ft with them.
· SOFA KING WHAT?
Here you go man.
· SOFA KING WHAT?
· SOFA KING WHAT?
I think it was him..........purevil. He has a procharged mustang right?
1 - 16 of 16 Posts
