21 - 25 of 25 Posts
As horndog has pointed out in previous posts, check and clean all grounds. Make sure that the block heads, transmission and the battery are all grounded to the frame through a clean connection with no paint or contaminents between the frame and ground straps/wires.
How is your battery? MSD needs +12 voltage, if it drops at the box it'll show symptoms. I know many many cases where car would crank but not fire. After charging the battery just wrooooooooooooooooom wroooooooooooooom again. These were cars without alternator.
21 - 25 of 25 Posts
