1 - 20 of 25 Posts
Will idle fine. Will pop during burnout and occasionally when goes down on transbrake. Will pop all the way down the track. We have exhausted possibilities of what to check. Any advice??
Disconnect the tach as well as check all grounds. That's the first things I always check. Alot of the times it's the tach.
Are you running a crank trigger?
If so, what is the gap of the pick-up to the magnetic wheel?
Plug gap?
Grounds -- as mentioned .... very important that the ign box ground wire goes to the battery
You've eliminated the fuel side?
Valve springs? All check good?
Discussion Starter #9
Yes
0.050
Started at .035 went to .042 no change
Not sure where grounded but same as previous box
Fuel check
Valve springs checked
Have you done any wire rerouting maybe and caused some sort of interference between wires. There are some on ignition systems and crank triggers that need to be isolated
Discussion Starter #16
Yes. The whole combo.... motor, trans, intake, fi/na/n2o. timing, rpm, fuel, fuel cell location, fuel system, ..ect....
Naturally aspirated stock bore 454 with steel heads. Powerglide trans with brake. Msd cranktrigger with msd 6hvc box (new) with msd multifunction pn8979 also. 16 y/o. Sunoco 112 with prostar magnifuel 500. Fuel system is in rear.
Discussion Starter #17
Are you using the 8250 coil? That is the only coil that is supposed to be used with the HVC ignitions.
I don't know if using the wrong coil would cause the misfire or possibly damage the box and/or coil.
Correct coil and have even swapped
No. Same as last year started 1st race this year
Yes
0.050
Fuel check
Drop the plug gap back to .025 - .030
Check ALL grounds for cleanliness. Box ground really should be terminated at the battery.
How old is the fuel?
Carb clean inside?
Have adequate fuel pressure when engine is under load?
Can you monitor fuel pressure going down the track -- is the fp gauge mounted on the cowl?
1 - 20 of 25 Posts
