1 - 9 of 9 Posts
I have a '03 Mustang BBF with twins they are mounted behind the bumper cover under the headlight and I am trying to figure where to run the 5" pipes to get them out behind the front tires, I don't have much room over the tires or on the inside of the tires like close to the K member!! Sure is tight in there!! What are most guys doing I Though on the inside of the tires but man what gives here!
HeadCaseRacing
Why not go from 5 to 4 in Alum? Are the headers under or over the motor plate? Its going to be hard to see from picture since its a picture. Get the car on a lift and just see what to do.
i would take the 5" and go right down to 4". it will be easier to work with.
there is a 5" to 4" adapter that clamps to the back of the turbo and then run in 4". it makes it alot easier to get around everything
Custom Engine Shop
If you have tubular crossmember just run the exhaust thru it.
1 - 9 of 9 Posts
