1 - 8 of 8 Posts
7700 max rpm bbc,I think install height is around 2.000", not positive. 2.3 intake, 1.9 exhaust severe duty valves, bushed red zones, lightweight steel retainers
What's the intake valve weigh?
What's duration @ .020" on both sides? Call Steve and ask if you don't know.
Dunno about duration. Cam card is above. 143 grams I believe is intake weight... prob gonna run 2.1"valve.....221456 seems to fill the bill, but ouch, $650a set. I racer buddy said a triple may be safer. Prob would be cheaper anyways... thoughts?
EFI/N2O JUNKIE
Shit! I guess I should kiss my buddy that got me my polished PAC springs, could buy two sets for what you are paying!
I've run Pac 1224, Isky red zone, Trend 7/16" x .165" tapered in My Mopar 2.25" ,1.88" Ferra BB Chevy+.100" steel valves, 7200. 285/[email protected]" .800" lift so I shimmed them to 1.950" height. After 200 passes I pulled and checked, zero pressure loss. Going on 300 passes now. Check 1228 as well. Could shim to 1.950" for additional pressure.
Doug
There's a world of difference between a PAC and a NexTek spring. Manley NexTek springs are made by associated spring, and are comparable to PSI.
1 - 8 of 8 Posts
