Whos flare tool are you guys using to plumb foggers? The ones I am getting from the parts store aren't cutting it.
its the wrong flare for AN. AN is 37*a single flare 45.
WHAT? your going to use teflon tape for nitrous ? Not worried about that stuff getting into the nozzle/jet etc...??The 37 deg flair kits work pretty good for tight spaces,,allows for some sealing crush, use a couple wraps of teflon tape up under the flair so that when it sinches down it pulls the tape up and helps to seal better
When ever I want something to be accurate with any hole saw. I drill a pilot hole first,then I install a transfer punch where the drill bit goes into the hole saw.[/quote]Ridgd hole saws suck ass, dont buys those,,they wobble bigtime on the arbor. Fucked up a set of new alum valve covers with those saws.
