1 - 20 of 30 Posts
Godspeed TK!
Iam thinking of double beadlocking my wheels(15X10 Alumistars w/4in.BS)...........The only reason is Iam thinking of doing it-is because Iam tired of dealing with trying to get my radials mounted all the time & was told if I had "doubles"-I could mount & dismount tires myself. Especially since I have 4in.BS? If anyone could give me some advise on this-I'd appreciate it!
Oh-Will it affect the sidewalls of the tires? I currently run the Hoosier 275/60's w/glue & have been 1.20 60ft.-Dont wanna lose my 60ft!!!!!
yes u could change them your self with the beadlocks in about an hour. We do conversions and are offering a 5% to all YB members if your intrested give us a call thanks bruce Exstremefab.com 203 909 6732
yes Chris, we have the doubles and change our own tires
Godspeed TK!
No problem changing them yourself. ours are 3" backspace, but i think they might be hurting our sixty ft !
Iam definetely worried about losing some 60ft.:(, I have been told the beadlock will stiffin' up the sidewall??
Only problem i ran into was clearing the calipers ! Make sure you have them clearenced for brakes if needed . I run wilwood brakes on a fab nine if that helps
You know how anal Brian Mitchell is about weight and his 60 ft but i had his done for him from Champion and he has been very happy with them,,,let me know if i can help u out
chad
Our kit run a diffrent inner lock kit to clear the rotors we have car out there that the beadlock sit on center with the rotor and clears with no problem. and a beadlock will stiffen up the side wall in most cases that helps guys out but in other cases u will have to adjust your tire psi from no beadlock to when running beadlock . thanks
DOO DOO BROWN
Chris can you not run a 12" wheel with a 275?? I figured you had 12" wheels on your car.
Confused Racer
I just bought weld dbbl beadlocks for my true 10.5 stiff sidewalls. I run a tube on a 12" rim. M/T said keep the tubes it will be the same. Its not, lost some in the 60' I am now running 1lb less. I didn't get my 60 back yet but was at the grove not cecil for the second time out.
do you guys know if i can double beadlock a set of 15x12 holeshots with a 6 7/8 backspacing ? they are single now and was thinking about doubles ...
Weld Racing will convert your Weld Racing wheels to double bead locks. You keep your SFI as well if you have the manufacter do the conversion.
1 - 20 of 30 Posts
