1 - 19 of 19 Posts
1-877-MOD-POWR
Dont let this part destroy your COYOTE or GT500 engine!! The problem and the fix >>>>
MMR has had a overwhelming # of calls from engine builders and customers across the country with broken/failed lower crankshaft sprockets. It seems the majority have been those with upgraded camshafts but many have also been stock applications. We even received a call from a MMR dealer (BBR) who had even broke 2 on the same engine. When this part breaks catastrophic failure is certain (bent valves, damaged pistons,cylinder heads etc). MMR went to work quickly on a solution and are now selling the MMR Billet Steel gear. This gear replaces the factory powdered metal gear directly with no other changes, the MMR gears are manufactured from billet 9310 heat treated material and precision made in the US by MMR. If you are building aftermarket engine, have a Ford Racing Aluminator, or rebuilding a coyote engine you need one of these!!! Retail on the Billet steel gears is $219.
Order here:
GT500 ALL http://www.modularmotorsportsracing...in_page=product_info&cPath=21&products_id=414
2011-2014 http://www.modularmotorsportsracing...page=product_info&cPath=26_27&products_id=579
2015-2016 http://www.modularmotorsportsracing...page=product_info&cPath=28_29&products_id=580
Dont let this happen to you:
The new MMR Billet gear
1-877-MOD-POWR
Discussion Starter #2
Re: Dont let this part destroy your coyote engine!! The problem and the fix >>>>
bump
1-877-MOD-POWR
ttt
1-877-MOD-POWR
bump
1-877-MOD-POWR
Bump
Good excuse to get a stroker when these break
1-877-MOD-POWR
Discussion Starter #7
You will certainly need it if they break!
Coolant cross over kit and this gear is on the list.
1-877-MOD-POWR
Discussion Starter #9
Re: Dont let this part destroy your coyote or GT500 engine!! The problem and the fix
bump
1-877-MOD-POWR
Discussion Starter #10
ttt
1-877-MOD-POWR
Discussion Starter #11
ttt
1-877-MOD-POWR
Discussion Starter #12
ttt
1-877-MOD-POWR
Discussion Starter #13
bump
1-877-MOD-POWR
Discussion Starter #14
bump
1-877-MOD-POWR
Discussion Starter #15
bump
1-877-MOD-POWR
Discussion Starter #16
bump
1-877-MOD-POWR
Discussion Starter #18
ttt
1-877-MOD-POWR
Discussion Starter #19
ttt
1 - 19 of 19 Posts
