Or does everybody like the mickey thompson? Never seen anybody run the hoosier's......
What do you get for a set of 275/60/15 . I have a new set but in never hurts to check. Ran the MT had the best of 1.26 60ft with them. Also had very good luck with M&H same 60ft. Several of the people that run our local track run the hoosier, I think they work better than the MT on a marginal track, the MT on my car either hooks solid or they blow off, the M&H might shake a little but I could drive through that. Have not yet ran the Hoosier.I have a cuatomer who finally tried a set of the Hossier Radials after the MT's were so difficult to get. He was very pleased with them and stated he ran his best 60 ft times/et's ever with the hoosiers. I know it hard to switch sometimes when you have something that works, but I don't think you will be disappointed if you try the hoosiers. Good LucK
Give me a call when you have a minute. If you are local use the 954 area code. If not just change area code to 800 and you can reach me toll free. I'm not online everday. Sorry it took so long to get back to you.What do you get for a set of 275/60/15 . I have a new set but in never hurts to check. Ran the MT had the best of 1.26 60ft with them. Also had very good luck with M&H same 60ft. Several of the people that run our local track run the hoosier, I think they work better than the MT on a marginal track, the MT on my car either hooks solid or they blow off, the M&H might shake a little but I could drive through that. Have not yet ran the Hoosier.
Thank you for the kind words. IRR is a great place to race. Ralph always treats the racers well and they run a good program.GLPerf is a good one to deal with. Always at Immokalee when I raced down there.
Do you run Stock Suspension? Are you leaving offa Trans Brake? Just trying to figure out this new Combo and get it to Hook I believe we will have to put more air in the Tire,I know it moves a inch Each Pass and it's Spinning out of the holeI RUN THE 295/65, i have run both and the best 60' with the MT 1.28
Best so far with the Hoosier is 1.29,
the Hoosiers do like more air, i ran 17-18 with the MT and 20-21 so far with the Hoosiers
The Hoosiers do have a softer sidewall, and are more like a radial slick, they work just as good on my car, although it may be considered slow at only a mid 8 sec car
The Hoosiers are a little lighter also
I dont see why anybody would not run them, i like to have different options so i can just get the cheapest tire that works LOL LOL
I ran 16psi in the MT and 17 to 17.5 in the M&H. I like the M&H much betterI have seen the M&H's in the catalogs, but didn't know anyone that had ever tried them. They have a ton of tread, so I wouldn't have guessed they would work so well. What kind of air pressure do they like compared to the M/T's?
