1 - 20 of 24 Posts
Racingjunk add.
NEW COMBO FOR 2010...
Dart Iron Eagle block 9.5" deck and 4.125" bore, Eagle 4340 crankshaft, internally balanced and windage profiled. Eagle h beam rods w/ arp 2000 bolts. Custom JE pro series custom pistons w/ trick .043" ring package, ceramic coated crowns for more power and protection from detonation. King alecular pro eangine bearings, professional Products sfi damper, TFS r series heads cnc ported, with a little touch up work, ceramic coated chambers for more power and efficiency, assembled w/ extreme duty valves and Manley Nextek springs and titanium retainers 10* locks, Scorpion pro series race rockers and double bar stud girdle, comp cams custom solid roller camshaft and Comp Cams solid roller lifters, billet double roller race chain, Milodon drag series oilpan and pick up, melling hv oilpump, and steel pinned driveshaft, Edelbrock dominator intake manifold, polished alum valve covers. Set up to take up to 300 hp well tuned n2o. 850 hp on sheer horsepower add 300hp in a plate race car, and you have the power it takes. Engines are machined, balanced, assembled and then dyno tested in house prior to shipping.
what kind of heads will make 850 hp? I read about victor sr, glidden victor, yates, ect... any idea about the aussie cleveland heads or something else?
All motor wannabe
1 - 20 of 24 Posts
