1 - 2 of 2 Posts
I put on a new set of 275 and they spun a 1/4 of a inch on the only pass I made. It was a 1.320 -60' at 2900 lbs. I was told that they will do that at first and it will stop turning.
I'm not sure if I belive that. Do I need to glue them or will they stop turning?
Montgomery Ragland
I have done both. Glued or not they moved. after the first 2-3 passes they seem to stop.
Last set I did not glued they moved about 4" around the rim, 2nd pass they moved about another 2-3" then 5 passes later they were still in the same spot. About a total of 6-7" from the valve stem. Your results may very.
1 - 2 of 2 Posts
