Its a lot easier than you would think. Took me a few hours over a couple nights after work building it while watching TV to get it together. I have no experience with computers, circuit boards, etc. I read through the Megamanual assembly steps a few times before I started. They kit is just a bunch of small zip lock bags that are individually labelled, very nicely I might add. One bad may have one part in it, another may have 5 of the same part in it, and the label will read what all they are used for. Assembly is just taking the piece out of the bag at the appropriate step, making sure the piece is the right way around, then soldering it into the labelled spot on the board, and then snipping the leads.
Do yourself a favor and buy a MegaStim when you make the purchase, or borrow one from someone. I didn't use one on my MS1 build until everything was done, but it still helps to have one to test everything at the appropriate intervals while you build the board.
Good luck and keep us updated.
