Hey guys, Im a young wrencher and just last night signed the papers to my very first home, great feeling, but also a steep learning curve. The garage is (obviously being a gearhead) on the top of my to do list as I move in. I have an extremely short closing date in less than 2 weeks and need to learn and plan alot.
I am lucky to start with a 2 car 2 door garage. The interior dimensions are approx 19.5 X 19.5 and about 7.5 feet from floor to roof joists. It also has a breaker box panel, but I think Id like to redo all wiring. As it stands right now the entire garage is insulated between the studs, but the walls literally have thick cardboard holding the insulation in, so that needs to go.
Im hoping some of you DIY'ers can recommend some proven materials for the walls, I will be working in the garage alot, occasional welding/grinding, woodwork,spray bombing, part sorage, usual DIY racer stuff. Being this is my first house, the Ive got lots of youtube videos to watch, money isnt a huge issue as I having savings but Im pretty thrifty, but I am great with power tools and take my time to do the job right and look nice.
As of right now, I think something other than drywall should be used on the bottom 4' of the walls, possibly OSB, and either drywall or pegboard depending on cost around the top perimeter of the walls. Im new to construction, but do I just leave the insulation between the studs, put up a vapor barrier, and install my coverings?
Obviously I will need a bench, most likely will be a simple 2X6 construction, Im a little lost on placement, to have it all across the back wall, possibly an L in one corner, along a side wall. Any tips for placement and sizing, I need to mount my large vice osomewhere. Construction of the bench and materials seems straight forward enough. I like simple designs like this
When it comes to the wiring and lighting, that needs to be planned out I guess, I prefer the recepeticles up higher, any reaason not to? I plan on just removing the shotty looking stuff in there now right back to the breaker box and run my own receptacles and maybe 2 long overhead light bars with fluorescent lights, maybe just keep it simple with 2 regular bulbs? Budget depending.
All in Im budgetting the garage could hopefully be finished for $600-$700, Im thinking wall coverring may add up the fastest, as I said Im a new home owner and this is a little daunting but very do-able for me, just need a shove in the right direction to having a lasting garage to call my own.
Cheers guys!
Cheers guys!
