1 - 3 of 3 Posts
from across the pond...
Does anyone know where i can get one for a 10.2 deck BB Chevy with a dry sump system?
Mallory do a short deck plug which is part number 29002. I just need a blank one,no gear required to drive a pump.
Appreciate your help in advance...
if you do not need the shaft with a gear or something to operate the TACH, or anything such as that..
then just put a plug in the hole......
to be able to route oil pressure to the lifter galley....
I understand that,but for the sake of quickness it would be easier if i could just order one to drop in...
If one isn't available then i'll have to do what you suggest.
1 - 3 of 3 Posts
