I finally decided to buy a vacuum gauge for helping tune the carbs a bit, Edelbrock 750s, on my 6-71 blown SBC. I was going off the vacuum/boost gauge in the car, but it was a pain to make an a adjustment and then walk back to the drivers window to see the reading.
Anyway...I found that when I hooked up the vacuum gauge to a manifold source on the carb it was 4" higher (14" reading) than the gauge in the car (10"). Should I be selecting my step up springs based off of the gauge at the carb fitting or the gauge in the car? The gauge in the car is hooked up to a fitting installed on the back of the blower manifold.
