1 - 3 of 3 Posts
Pssst is a waist of boost
All,
In the instructions it said to use 80-100 PSI
As I run a CS1 Lenco I have 150PSI - CAn I run this to the throttle or should I get a seperate regulator.
I do have two bottles that I can mount but both regs that I have are fixed to 150psi.
Was thinking of using seperate air systems as I don't think I want to have the Air line to the throttle "come adrift" and cause the lenco to down shift.
Can you just go to BOC and get one?
1 - 3 of 3 Posts
